1 - 7 of 7 Posts
the car died for more than a month, before it died, it vibrated a lot, and then died. I figured out what caused the vibration, the #3 injector was bad, I just replaced this injector today, but car still won't start up.
I recorded the sound that I started up my car, who can tell me what happened?
the sound of start up
CH0DEmobile
Yep, your starter is working, but it sounds like you've got a pretty weak battery. It almost sounds like you've got low-to-no compression, but I could be wrong, that was a pretty short clip. Change/charge your battery, and see if it'll start. Make sure you're getting a spark and fuel, maybe you disconnected something while installing the injector?
Newer electronic FI engines take a lot more power to start up. Your starter sounds OK. Sounds like no spark or fuel- I'd check those items out first.
Pizdeet kak Trotsky
Don't sound like its firing ........ & it could do with spinning over a lil quicker :)
Actually, I checked the spark plug by pulling them out, and connect to engine body, it has spark, and i put a stick into engine, there is also fuel spray on it while i try to start up the car. But i don't know whether the fuel injected is enough?
I unplug the pipe runs to top of the fuel filter, and put another test pipe on it, and turn key to "on", there are fuel pumping out.
1 - 7 of 7 Posts
