if you want plug and play then just use your stock ecu and maf.
the only VE ecu that will work that is 5 spd is a 16ve one. if you used that ECU, your cams will kick in at the wrong times and your fuel curve will be way off. you would still need some method to tune it.
just use your stock ecu for now or get a JWT.
