Pining for "DMSentra"
Luke, been reading on this. It sounds like the inner cv and the shaft is the same as a SE-r, the outer cv is G20 specific. Also, if you can find which Se-r length is right the spline on the shaft is the same so you can swap your outer on the Se-r shaft. Or maybe your shaft and outer into an Se-r inner cv.
