Status
Not open for further replies.
1 - 20 of 42 Posts
It's been fun, but I think it's time for us to part our ways... After two years it's time to move on to something nicer and hopefully AWD :teeth:
Overiew
2000 G20t KH3, 128k miles, original Roller Rocker, and 6 Speed w/ABS!, AC
Prices are OBO
NA Price: $3,500
Turbo Price: $4,500
Car spent most of it's life in Texas, and about 4 years in VA/MD, has slight rust in the trunk.
Car is currently turbo, I will be returning it back to stock over the next few weeks (or days if someone is really interested).
Engine
SR20DE RR with 114k miles (Original RR, I had a VE in for 14k miles.)
Block is tapped for turbo (had turbo for 8k miles)
Supertech Valve Seals
VE Valve Springs (dual valve springs, can be revved to 7500 rpm)
Brand New Valve Cover seal (no leaks!)
Lowport Oil Filter location
Lowport Intake manifold (10whp na increase)
OBD1 repinned harness
B13 ECU with Basic Board
With NA you get
Stock Header
Stock sized exhaust
259cc Injectors
Stock Radiator
P12 Clutch/flywheel
With Turbo you get
Avenir T25
Avenir Manifold
Avenir Jpipe
3" SS Downpipe
3" SS Exhaust + Borla Resonator
370cc Injectors
Z32 MAF + Pod Filter
Walbro 255lph fuel pump
B15 aluminum dual core radiator
JWT Flywheel + Exedy Stage 1 350z Clutch
B15 ES Motor mount inserts
Maxima ES Cross Member bushings
Transmission
03 Spec V Gearset, under 10k miles
Helical LSD
EMPI Axles
Mazworx Axle bracket
Gspec SS clutch line
For installation pics: 6 Speed Swap pictures/Guide
Suspension & Brakes
Stock Shocks/springs, Stock shocks/springs rear. Will include low mile KYB Front shocks.
0 Toe Beam
ES Rear beam bushings
ES Lower Control Arm Rear bushing (A33 Maxima Shaved to fit)
Technafit SS brake lines
Hawk HPS Pads
Brembo Blank Rotors
SS Power steering hose
Power Steering cooler
205/60/15 Yakohoma AVID ENVigor with plenty of life
Interior/Exterior
Sound deadening material on the floor
Fog light mod (stays on with parking lights)
B14 corners (on with lights and blink)
Painted Meshie rims
Blacked out bumper lights
Black Leather interior - Car originally came with tan interior.
Seatbelts and removable plastics have been replaced with black interior ones. The leather on the front seats have seen better days. If I find some good conditioned upholstery I'll reupholster them.
Sport Side Markers
Stock Headlights
Stock Grill
Stock Head Unit
Stock Speakers
Pics
Exterior
Typical 14 year old paint job, definitely has nicks and scratches
Only major damage is on the fender
Engine
6 Speed pics
ABS Ring modded to work with P11 hub/sensor
http://images.rvsmods.com/var/albums/Cars/G20tKH3/Mods/Drive-Train/6-Speed/Axles/Axles_012.jpg?m=1368851290
Mazworx Axle carrier bracket, brazed so it doesn't rattle loose
Sadly the cable was ripped so I had to improvise
Shift Assembly
Sound deadened the front floor
OBD1 Repinned harness
Forgot to mention, the car does have a 0 Toe beam, from 1/8" toe in. Made a really nice difference with low speed turning. I'm trying to decide what's worth the time to remove and what I should leave on the car, exterior/interior pictures will come after that.
The G20 hoarder
good luck on sale.
few questions,
1. you put stock ve valve springs in the RR and it worked?
2. how did you get a lowport inake mani to fit the RR? pics please.
3. would you sell that patch harness separately?
4. by 0 toe, you mean you had the toe straightened on the rear beam like the b15 guys do?
good luck on sale.
few questions,
Sure answers and pictures are below. Btw looks like I will never get around to using the JDM manifold to test it. Unless my lowport rail magically fits on it as I'm stripping the car down.
Yup, been driving for 10k miles with VE valve springs and boost.
Detailed post can be found on SR20-Forum.com
You need VE inside washers though
This one is fairly easy, but you do need to do some cutting on the water pipe. This allows you to use sidefed injectors and old styled IACV with your older ECU (stock 32bit ecu wont be happy).
Detailed post is once again on SR20-Forum.com
Issue is LP manifold's water neck hits the RR stock pipe, and there is not much room for an elbow without cutting.
Stock pipe can be modified to work
Rest is just bolting it up like the stock mani
Once you get it in, there is one slight clearance issue with TB, thermoblock spacer helps fix it
Oh and PCV valve is in the way a little
But at the end of the day you get 10whp gain (On b13 stock tune), so it's worth the trouble
I actually haven't ran the step down harness for a long time already, so yes I can sell it to you right now. I repined this car's ECU harness because of a much cleaner look.
My old harness wasn't pretty but it got the job done.
I cold bent the beam to 0 toe with toe plates. B15 guys use heat mainly, you need a powerful torch for heat, plus with heat the beam changes toe once it cools down, some say heat also weakens the metal.
I've checked the rear toe multiple times with my toe plates after couple hundred miles and it's been spot on.
Discussion Starter · #8 · (Edited)
Bumping this up, reduced price. Removed cloth seats/doors, JDM center console, and other little price increasers and I'm down to this. I would like to sell the car 6 speed and OBD1, saves me the trouble and someone else who plans to turbo/convert to OBD1 anyway.
NA Price: $4,000
Turbo Price: $5,000
With NA you get
Stock Header
Stock sized exhaust
259cc Injectors
Stock Radiator
P12 Clutch/flywheel
With Turbo you get
Avenir T25
Avenir Manifold
Avenir Jpipe
3" SS Downpipe
2.5" exhaust
370cc Injectors
Discussion Starter · #13 ·
Long overdue engine bay pictures, just finished installing the T25 and injectors.
Space is a little tight with the stock sized fans
Z32 MAF, flange removed, thus it's 3" in and out, can be setup as blow through.
370cc injectors
1 - 20 of 42 Posts
Status
