1 - 13 of 13 Posts
2002 Nissan Sentra SE-R Spec V with SR20VE motor. Car is located in Elk Grove, CA. Car raced in a few races in NASA's SE-R Cup (SRX) and in Performance Touring (PTB). Can be demoded to run in PTC. Selling to finance other projects.
$17,000 obo. You can reach me at [email protected] or (916) 479-5551. Please email me instead of replying to this post. Thanks!
John Almazan
Engine and Driveline
Engine Make: Nissan SR20VE NEO VVL
Displacement: 2.0 liters
Output: 169 WHP
Redline: 7200 rpm
Engine Management: Jim Wolf Technology (JWT) VE ECU
VVL Activation: Greddy Multi Switching System
Camshaft: stock
Connecting Rods: stock
Pistons: stock
Crankshaft: stock
Cylinder Head: stock
Throttle Body: stock
Injectors: stock
Intake Manifold: stock
Intake: Custom
Exhaust: 3-inch open exhaust/Magnaflow exhaust (track dependent)
Exhaust Manifold: Fujitsubo
Fuel Pressure: NISMO Fuel Pressure Regulator
Radiator: Fluidyne
Water Pump: Mezeire Electric Water Pump
Oil: Mobil 1
Oil Cooler: Setrab
Oil Filter: stock
Oil Pan: stock
Transmission: Stock 2002 QR25DE 6-speed
Differential: Helical LSD
Bell Housing: Nissan Primera Bell Housing
Transmission Oil: Nissan Manual Transmission Fluid
Clutch: Jim Wolf Technology (JWT)
Flywheel: Jim Wolf Technology (JWT)
Pressure Plate: Jim Wolf Technology (JWT)
Motor Mounts: Energy Suspension
Interior/Safety Equipment
Belts/Net: Crow
Gauges: Autometer
Pedals: stock
Roll Cage: Steve Scott 8-point rollcage
Seat: Sparco
Steering Wheel: Stock
Suspension
Type: Struts front, multi-link beam rear
Anti-roll Bars: Stock front, NISMO adjustable rear
Strut Tower Bars: Custom Tolle Fabrication front, none rear
Bushings: Energy Suspension
Struts: Koni
Springs: Hyperco
Steering Ratio: stock
Brakes
Type: Stoptech front, stock rear
Fluid: Motul
Lines: Stoptech
Pads: Pagid RS-14 front, stock rear
Wheels and Tires
Wheels: NISMO 17x7.5 in.
Tires: 235/40R17 Toyo Proxes RA-1
Spacer: H&R front, none rear
Body
Body Construction: Nissan B15 stock
Aerodynamics: Syndicate Kustomz fiberglass front lip, Pogy rear wing
Windshield: Shields Lexan
Rear Windows: Lexan
Paint: Miracle Auto of Napa
Weight: 2370 lbs
Its the white B15 I think I remember it, very clean car
randyo156 said:
so does a qr25de 6 spd mate to a sr20det?
Yes with a different custom bell housing
Discussion Starter #11
gdubb said:
bump someone buy this thing if i had the money id get it
I just got off the phone with the owner.. nice guy...
If there was a practical way for me to own and store and transport this car, I would get it..
I hope someone else here get's it!
1 - 13 of 13 Posts
