A/C cycling cold then luke warm....
954 views 4 replies 5 participants last post by  mpek02
#1 ·
I suspect the problem is that I am low on 134A, but please let me know if I am overlooking anything. I have a 93.5 G20 and my a/c will blow very cold for 30 seconds or so then cycle off and blow lukewarm air for a couple of seconds, then go back to cold. What is going on? Please help.
#4 ·
A/C problems can be caused by either leaks, clogs, or poor pressures. Everyone tends to point towards the compressor for bad a/c performance, but it's not always the case. Diagnosing a/c problems is easy if you know what you're doing. First the system should be evacuated to see how much refrigerant comes out. Then FULLY re-charged, and ran for 10-15 minutes while checking for leaks with a leak detector and monitoring the hi and lo side pressures. Half the times, a leak will be found...the other half the times, under spec pressures will be found. When you find a leak, its easy to fix, just replace the leaking part. When pressures are off, but no leak is detected, it can get tricky. It can be from the compressor malfunctioning, it can be from a clog, it can be from a malfunctioning expansion valve and/or receiver/drier. You need to know how to look at the pressures on both sides to properly detect the problem. If you cant do this yourself, take it to a GOOD shop, the dealer is probably the best place because if it is mis-diagnosed and repaired the first time, they will re-repair it free of charge the second time around.
#5 ·
I've noticed same on my' 94 with R134 in it.On a humid upper 90s
day when working full force,the A/C will go in cycles like 30 sec on then 15sec off.I can feel it kick in and out while driving as surges in RPM.Checked the Low end pressure myself with gauges from Walmart.Shows 40-45 psi.What the hell is making
my A/C go like that?
