How To: Change Oil
43K views 33 replies 25 participants last post by  Dane
#1 · (Edited)
Search: How to oil change, oil change, changing oil
Since not everybody knows how to change their own oil, this is a write up on the quick and nasty for doing it. Its pretty easy and you only need a few tools.
- You will need the following: 4 quarts of oil (your choice), new oil filter (your chioce) 14 mm socket, funnel, oil pan, hand cleaner, paper towels, floor jack, and a creeper is nice but not necessary. Make sure the engine is slightly warm...this helps the oil drain, but dont make it hot our you can burn yourself.
- First step, put your emergency brake on, and jack up the car from the passenger side.
- Locate the drain plug
- Another View
- Take your 14mm socket and remove the beast...try not to get all dirty and such. If you do, thats what the hand cleaner is for. Let drain....a good idea is to lower the car back down to ground level and let it drain completely.
- Now its time to remove the old oil filter, you can see the pulleys in this photo to give you a better idea. There isnt a whole lot of room here but it will come out from the top. If the bugger doesnt want to unscrew then you might have to take a long flathead screwdriver and use some *gentle persuasion* to get it out. If you need to do this, try not to puncture the oil filter casing, or youll end up with a mess....remember righty tighty, lefty loosey
- Note for 2000+ G20's The oil filter location is now on the back of the engine block, the side near the firewall. Use caution, you have to get under the car and remove from there....In my experience, there is no oil catch device for oil that is left in the filter and it will get all over the place....especially down your arm.
- Since there is always a little oil in the filter that will seep into the catch basin under the filter, use the paper towels to soak up the extra oil.
- Now take your new filter and rub a little of the new oil on the o-ring to help it seal. With this done, go wash your hands and install the new oil filter....You only want to put this on hand tight and use caution not to cross-thread the filter onto the threaded post.
- If your happy with the drainage, its time to replace the oil drain plug. Tighten this to a comfortable level...if you have a torque wrench, the torque values are 22-29 ft-lbs.
- Now remove the oil filler cap on top of valve cover and start filling away...I used the top from an old oil container as my funnel, and pour in 3 quarts of oil.
- The stock engine requires about 3-5/8 quarts of oil....this is approximately 5/8 of a quart already poured into the engine on a new oil container.
- Replace the oil filler cap, double check the filter and drain plug to make sure they are tight, and you are all done...start the engine, let it run for a couple of seconds check the oil level and add oil if necessary...
- Go have a beer/smoke and give yourself a pat on the back for a job well done....with enough experience it should take you about 20 minutes to do....might want to check the oil level again to be sure....
- Side Note: Please dispose of all the old oil properly...most oil change places will take your old oil at no charge...our planet has to last a few more years.
- Another Side Note: If your dipstick is reading full with less than 3-5/8 quarts of oil, there might be significant build up of oil sludge in the engine....this is common for engines that rarely go past 5000K on a regular basis...know as the Missing Oil Syndrome you can read the link to find out more about it...
#2 ·
what a nice guy, he even has pics!!
very good write up yah!
#3 ·
wow! nice post, Yahnozha!
btw: i've always been told to open the filler cap first to help it drain better - any truth to that?
it'd be nice if the maintenance section on the home page were updated with other how-to's. or at least sticky posts in the maintenance forum:
what does everyone think about how-to's with pictures for:
changing the fuel filter
changing the micro-filter
changing the coolant
changing the spark plugs
etc.
#4 ·
Some truth to that, so you can remove the filler cap before you start...
etc. [/B]
That would be a great idea....just need to find people willing to do this...
#6 · (Edited)
Hate to correct you P@, but the oil drain plug is 14mm not 17mm :)
Oh, I'd also add another point to the end. After your beer, you should check the dipstick!
Edit: Hey I just checked your post and it looks like you do have
a 17mm drain plug. I dont think that sucker is stock, man.
Every SR20DE Ive ever seen has a 14mm drain plug.
- Greg -
#8 · (Edited)
dsigns said:
Great write-up and great idea. How about a DIY or How-To section be added to the Menu?
Ive been thinking about this, and we'll probably make a FAQ (like the suspension section) with articles such as this in them...that way there are not a bunch of stickys on the forum.
Actually, my drain plug is 19mm...I thought the stock drain plug was 17....my bad :( Oh, and if you want to see what the Super Plug is catching at 141,000 miles, take a look here.
Ill make the changes....thanks for the heads up.
Also, on oil filters, what ever you go with, make sure there is a check valve in the filter, this keeps the oil in the filter and gets it to your necessary components faster than one without.
#9 ·
id be in on doin some faq's, how-tos, and such... im gonna be changing the fuel filter sometime this week, so ill snap some pics. i also am thinking of changing the gear oil for the tranny(m/t), so i may do a lil thing w/ that too. if anyone has any more suggestions, hit me up, im always ready to do some maintenance to my car :)
#15 ·
The write up is good except for one thing, never ever get under a car held up by only a floor jack. This write up needs to be changed to either jack it up and use a jack stand, or do as I do, jack it up and put three 1 1/2 foot long 2x6's under the passenger's front tire and lower back down. It is extremely dangerous to do otherwise.
There are a lot of younger inexperienced owners here who are attempting to do maintenance for the first time. We do not want them to learn unsafe practices.
#32 ·
+1
I always throw a jackstand under the car as a back up.
I was jacking my toyota minivan a few years back and the jack collapsed while i was jacking it up.. the van dropped on its wheels .
Good thing the wheels werent off and nobody was underneath it.
I never just rely on the jack.
good write up though!
Someone needs to add there comments on the 2000 up. I havent changed the filter in 2 oil changes. Dont want to get messy under there.
#18 ·
Disclaimer: Never use a jack to support the car if you plan on crawling under it....in this case, Im never under the car (well okay, my arm is) but use the jack to make it easier to wrench the drain plug out....if you have a 00+ RR motor, then yes use jack stands.
#19 ·
hey quick question guys... my oil is kinda brown on the dipstick, not really transparent so I was wondering what causes this. It's been like this since I bought my car almost 4 years ago, and it isn't burning any oil or leaking much for that matter :/
#20 ·
the oil in the car cleans, lubricates and cools your engine, so when it turns a darker color its picking up basically "crap" in your engine(dirt, old oil etc), turning it to a more brownish color
#21 ·
k, good, I know it was kinda a newbie question but I wasn't sure if my engine was running to hot or what, maybe I should try the oil treatment that P@ was talking about....
#28 ·
Changing oil has no bearing on how the engine runs. Unless you overfill it by like 2 or more quarts. You got something else going on. Since this is the Maintenance section, I will post all the oil analysis and filter analysis' that i've done to inform you all of the properties of different oils and dissuade some myths. Maybe they can even become stickies :naughty:
